メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
The speakerphone is used to talk hands-free on the phone. When this feature is not working, you may consider replacing it.
パーツ
パーツは指定されていません。
  1. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. Slide metal spudger into the crack around the Front Panel of the phone Be careful not to break the clips holding the Back Panel to the Front Panel Be careful not to break the clips holding the Back Panel to the Front Panel
    • Slide metal spudger into the crack around the Front Panel of the phone
    • Be careful not to break the clips holding the Back Panel to the Front Panel
  3. When setting the back panel down, be careful to not rip any of the wires off of the internal components
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove Front Panel as shown. Remove Front Panel as shown.
    • Remove Front Panel as shown.
  6. Locate Speakerphone  and remove solder with soldering iron. Locate Speakerphone  and remove solder with soldering iron. Locate Speakerphone  and remove solder with soldering iron.
    • Locate Speakerphone and remove solder with soldering iron.
  7. Use the soldering iron to reconnect the wires to the new speaker.
    • Use the soldering iron to reconnect the wires to the new speaker.
  8. Place new speaker back in place.
    • Place new speaker back in place.
    • Make sure that all of the components are back in place.
  9. Replace Back Panel as shown. Replace Back Panel as shown. Replace Back Panel as shown.
    • Replace Back Panel as shown.
  10. Secure the Back Panel with the same screws using the iFixit Protech Screwdriver kit J1 or PH1 bit. Secure the Back Panel with the same screws using the iFixit Protech Screwdriver kit J1 or PH1 bit. Secure the Back Panel with the same screws using the iFixit Protech Screwdriver kit J1 or PH1 bit.
    • Secure the Back Panel with the same screws using the iFixit Protech Screwdriver kit J1 or PH1 bit.
ゴール
ある他の人がこのガイドを完成しました。
Charles Messmore
メンバー登録日: 2016年02月15日
520 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 1-1, Harley Spring 2016 IUPUI, Team 1-1, Harley Spring 2016人のメンバー
IUPUI-HARLEY-S16S1G1
4 メンバー
7のガイドは作成済み
コメント1件
Why do all these repairs require NO PARTS to replace defective parts?
And, of course< there is no links to a place to purchase the needed parts...
rpoland - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 315
