はじめに
Step-By-Step Guide: Created By ATUS Service
This guide is used to provide step-by-step instructions for replacing the Cam Gear Assembly on all AT-LP60/LP60X and AT-LP3/LP3X models. The part being replaced has a possible link to inconsistent functionality of the auto start/stop function of the automatic turntable.
The part number for the cam gear assembly is 701-SL24F-192, and can be purchased through the Audio-Technica parts department; (330)686-2600 ext.5002 || parts@atus.com
必要な工具と部品
Unplug the power source located on the back of the turntable.
With your right hand, hold the tone arm in the rest so that it does not move.
With your left hand, slowly rotate the platter clockwise until you hear a series of clicks.
Cam gear assembly - white gear visible through holes of the platter.
Gently pull the belt up and off of the gold pulley.
Remove the platter by grabbing the platter from the two circles, and pull straight up.
Once the screw is removed, pull the cam gear directly up to remove it.
Position the metal shaft against the metal bar.
Ensure brass bushing is lying flat in between the grooves.
Position the white plastic part such that it is touching the hole closest to the center post.
Place the new cam gear assembly on the center post, it will fall into place once the rest of this step is complete - DO NOT force the cam gear assembly down.
When the cam gear is placed, the open area of the cam gear should be facing the inner spindle as shown.
Locate the metal hook at the end of the spring, and gently slide it away from the cam gear until the cam gear drops into position.
Secure the cam gear assembly with the screw set aside from Step 5.
Flip the platter upside-down and ensure the belt is stretched around the inner ring.
Mount the platter back onto the center spindle.
Stretch the belt around the gold pulley.
ある他の人がこのガイドを完成しました。
