はじめに
This guide will show you how to locate, remove, and replace the buttons on the AT&T NVG510 modem. In the event that a button becomes stuck or your router becomes unresponsive when you press a button, you may need to replace it. This guide does require you to be able to operate a soldering iron carefully.
必要な工具と部品
Place the router on one side so that the rubber stands are facing upward.
Remove the stands from the left corners only, relative to the AT&T logo if facing upright.
この手順で使用する道具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove two screws using a 2.0 flathead screwdriver.
3 の人々がこのガイドを完成させました。
