はじめに
Step-by-step guide in removing and replacing a faulty motherboard.
必要な工具と部品
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
With the metal tweezers gently remove the fabric covering the connection on bottom right
Using the heavy duty plastic spudger pry up on the connection ribbon.
The protective plate is now ready to be safely removed.
With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
Remove loosened plate and set aside.
3 の人々がこのガイドを完成させました。
コメント 1 件
Where could i get the new replacement motherboard for that? Please inform.. thanks :)
Davy Jones - 返信
