はじめに
Once you have removed the battery you will be able to remove the motherboard from your device. Make sure the battery is completely removed before working on the motherboard as to prevent shorts in the circuitry As a precautions ground yourself to prevent frying the internal components. Also make sure to keep track of screws and label them.
パーツ
パーツは指定されていません。
Use the plastic tool to pry between the silver bezel and the back case
Work the tool around the device to free the back case
Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
ある他の人がこのガイドを完成しました。
2 件のコメント
Where can I buy a spare motherboard for this device.
Where are the motherboard sold and how do I purchase micro USB ports
Xibu Zhang - 返信
