メインコンテンツにスキップ
ASUS ZenPad S 8.0 Front Facing Camera Replacement
必要な工具と部品
  1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 手順 1、 3の画像 1 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 手順 1、 3の画像 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 手順 1、 3の画像 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 手順 2、 2の画像 1 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 手順 2、 2の画像 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 手順 3、 3の画像 1 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 手順 3、 3の画像 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 手順 3、 3の画像 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 手順 4、 2の画像 1 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 手順 4、 2の画像 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 手順 5、 3の画像 1 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 手順 5、 3の画像 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 手順 5、 3の画像 3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 手順 6、 1の画像 1
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
終わりに
作成者
1人の作成者と共同作成されました。
John Astfanous
メンバー登録日: 10/04/16
987 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S2G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,329
