メインコンテンツにスキップ
ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement
必要な工具と部品
  1. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Battery: 手順 1、 2の画像 1 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Battery: 手順 1、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 2、 1の画像 1
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 3、 2の画像 1 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 3、 2の画像 2
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 4、 1の画像 1
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 5、 1の画像 1
    • Peel back the silver tape.
  6. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 6、 1の画像 1
    • Disconnect the battery connections.
  7. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 7、 1の画像 1
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Speaker/Charger Port/Headphone Jack: 手順 8、 3の画像 1 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Speaker/Charger Port/Headphone Jack: 手順 8、 3の画像 2 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Speaker/Charger Port/Headphone Jack: 手順 8、 3の画像 3
    • Remove all screws 3mm, using the Phillips #00 screwdriver, at the bottom of the device.
  9. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 9、 1の画像 1
    • Remove the black piece.
  10. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 10、 2の画像 1 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 10、 2の画像 2
    • Unplug the wires.
  11. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 11、 3の画像 1 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 11、 3の画像 2 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: 手順 11、 3の画像 3
    • Using the pry tool, pry up the circular piece and remove the board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Henry Barrett
メンバー登録日: 09/10/18
546 ポイント
4のガイドは作成済み
チーム
University of Alabama, Team S2-G7, Bedsole Fall 2018 University of Alabama, Team S2-G7, Bedsole Fall 2018人のメンバー
UA-BEDSOLE-F18S2G7
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 1,024
