メインコンテンツにスキップ
ASUS X550LB-DS71 Motherboard Replacement
必要な工具と部品
  1. ASUS X550LB-DS71 Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Motherboard Replacement: 手順 2、 1の画像 1
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
  3. ASUS X550LB-DS71 Motherboard Replacement: 手順 3、 3の画像 1 ASUS X550LB-DS71 Motherboard Replacement: 手順 3、 3の画像 2 ASUS X550LB-DS71 Motherboard Replacement: 手順 3、 3の画像 3
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Motherboard Replacement: 手順 4、 2の画像 1 ASUS X550LB-DS71 Motherboard Replacement: 手順 4、 2の画像 2
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
  5. ASUS X550LB-DS71 Motherboard Replacement: 手順 5、 2の画像 1 ASUS X550LB-DS71 Motherboard Replacement: 手順 5、 2の画像 2
    • Locate the gold ribbon connecting the motherboard to the display.
    • Lift up the tape and disconnect the ribbon.
  6. ASUS X550LB-DS71 Motherboard Replacement: 手順 6、 2の画像 1 ASUS X550LB-DS71 Motherboard Replacement: 手順 6、 2の画像 2
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
  7. ASUS X550LB-DS71 Motherboard Replacement: 手順 7、 2の画像 1 ASUS X550LB-DS71 Motherboard Replacement: 手順 7、 2の画像 2
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
  8. ASUS X550LB-DS71 Motherboard Replacement: 手順 8、 3の画像 1 ASUS X550LB-DS71 Motherboard Replacement: 手順 8、 3の画像 2 ASUS X550LB-DS71 Motherboard Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    購入する
    • Flip the motherboard to show the underside.
    • Locate the two square connections attached to the motherboard.
    • Disconnect them using blunt tweezers.
  9. ASUS X550LB-DS71 Motherboard Replacement: 手順 9、 3の画像 1 ASUS X550LB-DS71 Motherboard Replacement: 手順 9、 3の画像 2 ASUS X550LB-DS71 Motherboard Replacement: 手順 9、 3の画像 3
    • Using the Phillips #0 Screwdriver, remove the seven 2mm screws at the marked locations.
    • Remove the heat sink from the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Nathan Dyer
メンバー登録日: 09/25/17
550 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S16-G1, Eyestone Fall 2017 USF Tampa, Team S16-G1, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S16G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 32
今までの合計 2,001
