メインコンテンツにスキップ
ASUS X502CA Left I/O Board Replacement
必要な工具と部品
  1. ASUS X502CA Left I/O Board Replacement, Palm Rest with Keyboard and Touch Pad: 手順 1、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Left I/O Board Replacement: 手順 2、 1の画像 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Left I/O Board Replacement: 手順 3、 2の画像 1 ASUS X502CA Left I/O Board Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Left I/O Board Replacement: 手順 4、 2の画像 1 ASUS X502CA Left I/O Board Replacement: 手順 4、 2の画像 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Left I/O Board Replacement, Left I/O Board: 手順 5、 2の画像 1 ASUS X502CA Left I/O Board Replacement, Left I/O Board: 手順 5、 2の画像 2
    • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
    • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
  6. ASUS X502CA Left I/O Board Replacement: 手順 6、 2の画像 1 ASUS X502CA Left I/O Board Replacement: 手順 6、 2の画像 2
    • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
    • Make sure the power strip is disconnected before pulling the board out.
  7. ASUS X502CA Left I/O Board Replacement: 手順 7、 2の画像 1 ASUS X502CA Left I/O Board Replacement: 手順 7、 2の画像 2
    • Slightly pull the unhinged screen up to free the board and remove it.
終わりに
作成者
2人の作成者と共同で作成されました。
Christian Spencer
メンバー登録日: 11/06/18
436 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018人のメンバー
UMASSD-GULBRANDSEN-F18S5G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 201
