はじめに
The screen is one of the most important parts of a laptop, as you won't be able to see anything you're doing without it, which is kind of the point. The disassembly isn't too complicated, there's just a lot of screws that need to be removed.
必要な工具と部品
Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
