メインコンテンツにスキップ
ASUS VivoBook S400C Speaker Replacement
必要な工具と部品
  1. ASUS VivoBook S400C Speaker Replacement, Remove the Bottom Cover: 手順 1、 1の画像 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Speaker Replacement: 手順 2、 2の画像 1 ASUS VivoBook S400C Speaker Replacement: 手順 2、 2の画像 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Speaker Replacement, Disconnect the Battery: 手順 3、 1の画像 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Speaker Replacement, Battery: 手順 4、 1の画像 1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Speaker Replacement: 手順 5、 1の画像 1
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Speaker Replacement, Hard Drive: 手順 6、 1の画像 1
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Speaker Replacement: 手順 7、 1の画像 1
    • Pull left and lift out the hard drive.
  8. ASUS VivoBook S400C Speaker Replacement, LED Board: 手順 8、 3の画像 1 ASUS VivoBook S400C Speaker Replacement, LED Board: 手順 8、 3の画像 2 ASUS VivoBook S400C Speaker Replacement, LED Board: 手順 8、 3の画像 3
    • Disconnect the ribbon cable connecting the LED daughterboard and the motherboard by lifting the white tab on the LED side of the cable.
  9. ASUS VivoBook S400C Speaker Replacement: 手順 9、 2の画像 1 ASUS VivoBook S400C Speaker Replacement: 手順 9、 2の画像 2
    • Pull out the ribbon cable on the LED side by pulling on the blue tab.
  10. ASUS VivoBook S400C Speaker Replacement: 手順 10、 3の画像 1 ASUS VivoBook S400C Speaker Replacement: 手順 10、 3の画像 2 ASUS VivoBook S400C Speaker Replacement: 手順 10、 3の画像 3
    • The LED board is held in place by a hook on the left end and a latch on the right.
    • Press the latch with a spudger while lifting with a fingernail.
    • Pull the LED board to the right to clear the left-hand hook.
  11. ASUS VivoBook S400C Speaker Replacement, Speakers: 手順 11、 2の画像 1 ASUS VivoBook S400C Speaker Replacement, Speakers: 手順 11、 2の画像 2
    • Pull out the black cable connecting the motherboard to the speakers.
  12. ASUS VivoBook S400C Speaker Replacement: 手順 12、 2の画像 1 ASUS VivoBook S400C Speaker Replacement: 手順 12、 2の画像 2
    • Deroute the speaker wire from the motherboard to the left speaker.
  13. ASUS VivoBook S400C Speaker Replacement: 手順 13、 3の画像 1 ASUS VivoBook S400C Speaker Replacement: 手順 13、 3の画像 2 ASUS VivoBook S400C Speaker Replacement: 手順 13、 3の画像 3
    • Using a metal opening tool, pry off the left speaker.
    • A fairly strong adhesive is used between the speakers and the body of the laptop, requiring considerable force to take apart. Work slowly and use caution when working near the delicate wires connecting the two speakers.
  14. ASUS VivoBook S400C Speaker Replacement: 手順 14、 2の画像 1 ASUS VivoBook S400C Speaker Replacement: 手順 14、 2の画像 2
    • Deroute the wires from the left speaker to the right.
  15. ASUS VivoBook S400C Speaker Replacement: 手順 15、 2の画像 1 ASUS VivoBook S400C Speaker Replacement: 手順 15、 2の画像 2
    • Continue to deroute the speaker wire to the right speaker.
  16. ASUS VivoBook S400C Speaker Replacement: 手順 16、 3の画像 1 ASUS VivoBook S400C Speaker Replacement: 手順 16、 3の画像 2 ASUS VivoBook S400C Speaker Replacement: 手順 16、 3の画像 3
    • Using a metal opening tool, pry off the right speaker.
    • It bears repeating that a fairly strong adhesive is used between the speakers and the body of the laptop, requiring considerable force to take apart.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Bryan Chung
メンバー登録日: 10/18/19
437 ポイント
4のガイドは作成済み
チーム
UC Santa Barbara, Team A-1, Bator Winter 2022 UC Santa Barbara, Team A-1, Bator Winter 2022人のメンバー
UCSB-BATOR-W22SAG1
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 19
今までの合計 1,019
