はじめに
The mSATA SSD is used as a cache for the HDD to substantially speed up disk operations and reduce boot time.
必要な工具と部品
Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
Using a spudger, lift up the plug connecting the battery to the motherboard.
Disconnect the I/O Board ribbon cable from the motherboard.
Flip up the retaining latch with a spudger.
Grasp the SSD by the sides and slide it out of the connector.
もう少しです!
終わりに
