はじめに
RAM is effectively the short term memory of the computer and contains programs that are running and data that needs to be read or written quickly. If the RAM fails or needs to be upgraded, it is useful to replace it. This guide shows how to replace RAM in the expansion slot on the Asus Vivobook Flip TP501U.
必要な工具と部品
Open the laptop until it is flat and lay it screen down.
Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
Remove two 4.8mm Phillips from the corners of the device.
Locate and remove the single 3.17 mm screw holding in the WiFi card suing a Phillips #00 driver.
Disconnect the card from the motherboard by pulling down on the card.
Unplug the two black and white wires from the bottom of the card. They should pop off.
ある他の人がこのガイドを完成しました。
コメント 1 件
does this laptop support ddr4 ram? i have looked everywhere and it doesnt give me a clear answer.
