はじめに
The keyboard panel contains both the keyboard and the touchpad of the ASUS VivoBook Flip TP501U. Removing it also grants access to the internals of the device, which allows for the replacement of other components. This guide will walk you through the steps of replacing the keyboard panel.
必要な工具と部品
Open the laptop until it is flat and lay it screen down.
Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
Remove two 4.8mm Phillips from the corners of the device.
もう少しです!
終わりに
