はじめに
The hard drive is the component of the computer that stores information such as files and programs. You will want to replace your hard drive if the drive is failing, almost out of storage space, or has slow reading and writing speeds. This guide will walk you through the process of replacing the hard drive in the Asus Vivobook Flip TP501U.
必要な工具と部品
Open the laptop until it is flat and lay it screen down.
Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
Remove two 4.8mm Phillips from the corners of the device.
Unscrew the five 4.8mm Phillips #00 screws holding in the hard drive mounting bracket.
Slide the mounting bracket towards the battery to disconnect the hard drive from the motherboard.
