メインコンテンツにスキップ
ASUS VivoBook Flip TP501U Hard Drive Replacement
必要な工具と部品
  1. ASUS VivoBook Flip TP501U Hard Drive Replacement, Keyboard Panel: 手順 1、 2の画像 1 ASUS VivoBook Flip TP501U Hard Drive Replacement, Keyboard Panel: 手順 1、 2の画像 2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U Hard Drive Replacement: 手順 2、 1の画像 1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U Hard Drive Replacement: 手順 3、 1の画像 1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U Hard Drive Replacement, Hard Drive: 手順 4、 2の画像 1 ASUS VivoBook Flip TP501U Hard Drive Replacement, Hard Drive: 手順 4、 2の画像 2
    • Unscrew the five 4.8mm Phillips #00 screws holding in the hard drive mounting bracket.
    • Slide the mounting bracket towards the battery to disconnect the hard drive from the motherboard.
  5. ASUS VivoBook Flip TP501U Hard Drive Replacement: 手順 5、 1の画像 1
    • Unscrew the hard drive from the mounting bracket.
    • Remove the hard drive from the mounting bracket.
    • At the time of guide creation, the hard drive was not in the device.
終わりに
作成者
5人の作成者と共同で作成されました。
Megan Phinney
メンバー登録日: 01/14/20
315 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,664
