メインコンテンツにスキップ
ASUS U57A-BBL4 Front Panel Assembly Replacement
必要な工具と部品
  1. ASUS U57A-BBL4 Front Panel Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 2、 1の画像 1
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 3、 1の画像 1
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: 手順 4、 2の画像 1 ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: 手順 4、 2の画像 2
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 5、 1の画像 1
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 6、 1の画像 1
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 7、 2の画像 1 ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 7、 2の画像 2
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 8、 2の画像 1 ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 8、 2の画像 2
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 9、 3の画像 1 ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 9、 3の画像 2 ASUS U57A-BBL4 Front Panel Assembly Replacement: 手順 9、 3の画像 3
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
終わりに
作成者
2人の作成者と共同で作成されました。
Isabella Bernardi
メンバー登録日: 10/18/17
671 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G4, Julie Fall 2017 UMass Dartmouth, Team S2-G4, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S2G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 176
