はじめに
This guide will help you replace or upgrade your random access memory. This replacement will be very easy and will only require you to remove some screws.
必要な工具と部品
Unscrew the two 3mm Phillips screws with the PH0 screwdriver.
Unhook the back panel by inserting your fingernail in the slot provided.
Lift the panel upward.
もう少しです!
終わりに
