はじめに
If your device is not properly playing audio or if the audio is distorted, it may be time to replace the speakers. Follow these instructions to replace the speakers in the ASUS Transformer Book Flip TP500LA.
必要な工具と部品
Slide a heavy-duty spudger between the back case and the computer.
Slowly work around the edges to undo the clips to fully separate the back case from the computer.
Gently lift off the back case.
Using a spudger or an opening tool, lift up each speaker to remove them from the device,
ある他の人がこのガイドを完成しました。
