メインコンテンツにスキップ
ASUS TUF Gaming FX505DY Battery Replacement
必要な工具と部品
  1. ASUS TUF Gaming FX505DY Battery Replacement, Back Case: 手順 1、 1の画像 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Battery Replacement: 手順 2、 2の画像 1 ASUS TUF Gaming FX505DY Battery Replacement: 手順 2、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Battery Replacement: 手順 3、 2の画像 1 ASUS TUF Gaming FX505DY Battery Replacement: 手順 3、 2の画像 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Battery Replacement: 手順 4、 2の画像 1 ASUS TUF Gaming FX505DY Battery Replacement: 手順 4、 2の画像 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Battery Replacement, Battery: 手順 5、 3の画像 1 ASUS TUF Gaming FX505DY Battery Replacement, Battery: 手順 5、 3の画像 2 ASUS TUF Gaming FX505DY Battery Replacement, Battery: 手順 5、 3の画像 3
    • Using an ESD-safe spudger, disconnect the battery connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Battery Replacement: 手順 6、 2の画像 1 ASUS TUF Gaming FX505DY Battery Replacement: 手順 6、 2の画像 2
    • Remove the 6 mm screw holding the battery in place using a Phillips #1 screwdriver.
    • Avoid cutting, puncturing, or otherwise damaging the battery. Li-ion batteries can combust or explode if damaged.
  7. ASUS TUF Gaming FX505DY Battery Replacement: 手順 7、 3の画像 1 ASUS TUF Gaming FX505DY Battery Replacement: 手順 7、 3の画像 2 ASUS TUF Gaming FX505DY Battery Replacement: 手順 7、 3の画像 3
    • Use a spudger to pry the retaining pin into the closed position to allow the battery frame to be removed.
  8. ASUS TUF Gaming FX505DY Battery Replacement: 手順 8、 1の画像 1
    • Lift the battery up out of the computer.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ronald Brodeur
メンバー登録日: 03/30/22
109 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022人のメンバー
UMASSD-MELLEN-S22S2G4
4 メンバー
8のガイドは作成済み
コメント 1 件
What Is the serial number of the battery ?
Hector Garcia - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 72
今までの合計 2,390
