はじめに
This guide is for replacing the back case of the ASUS TUF Gaming FX505DY.
This is a prerequisite for any guide requiring removal of internal parts, as the back case prevents access to internal components. Any problem found on the troubleshooting page with internal part replacement as a solution will use this guide. Be sure to check the troubleshooting page before beginning in case the issue is only software-related.
The back case is hardened plastic and inflexible. While it is difficult to bend, bending the back case only a little further than what is "safe" will cause it to snap.
Make sure to fully shut down the device and unplug any chargers and peripherals before beginning.
必要な工具と部品
Turn off the laptop.
Disconnect the charging cable.
Flip the laptop so the back is facing up.
ある他の人がこのガイドを完成しました。
