はじめに
Following this guide, you will be able to remove the external hard drive and replace it with a new one of your own. Make sure that you have a hard drive to replace the old one with prior to attempting this guide.
必要な工具と部品
Remove the six screws on the back of the laptop using a Phillips screwdriver.
Remove the back casing being held on by the one single screw. First lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
3 の人々がこのガイドを完成させました。
