はじめに
A guide on how to disassemble the laptop to reach the motherboard.
必要な工具と部品
Remove the 6 screws on the edge of the laptop using a screwdriver.
Remove the back casing being held on by the one single screw. First, lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
Remove the battery by sliding the switch circled in the picture and pulling the battery out.
Remove the DVD ROM on the side of the computer, by pulling it out. If necessary, use a plastic opening tool.
Don’t pull the DVD-ROM from the outside. Instead, use a Fixite Carbon Fiber (sprudger side) to dislodge it by pushing it. Under the ‘‘C’’ screw, there is a ‘‘T’’ shaped trench with the metal edge apparent. Push it out gently (on the right) and grab the DVD ROM with bare hands. The original solution may break the DVD ROM esthetic cover clips.
Flip the laptop over and pop the back cover off behind the screen, by grabbing it on either side and pulling it up, vertically off of the laptop.
There is a cable connecting the cover to the laptop, shown in picture 2.
Disconnect the cable by pulling apart the white connectors, shown in picture 3.
You may now remove the keyboard plate. Simply lift from the back, and pull it off all the way around.
Caution with removing the keyboard, as there are 5 ribbon cables that connect the motherboard to the keyboard (motherboard port locations shown in picture 2).
The ribbon cables must be carefully disconnected from the motherboard side, by flipping a latch on the port and pulling the ribbon out.
Top tips! I had to open the top to repair a broken audio jack. I managed to temporarily repair the jack(torn open when my daughter jumped up from the chair with headphones still connected). I was able to bend ot back on place, and heat welded the pladtic together. A replacement is on its way.
Showing what “flip the latch” means as in a diagram would have been incredibly useful. Taking my laptop to be repaired now since the “latch” was so cheap it broke.
8 の人々がこのガイドを完成させました。
コメント 1 件
What size are the screws in the battery bay if i may ask please? one of mine is stripped and i need a replacement.
