メインコンテンツにスキップ
ASUS ROG G750JW-RS72-CB Display Assembly Replacement
必要な工具と部品
  1. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 2、 1の画像 1
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Hard Drive: 手順 3、 1の画像 1
    • Lift up the flap using a plastic opening tool.
    • Hold the flap back with your finger.
  4. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 4、 1の画像 1
    • Unscrew the 5.2mm screw underneath the flap.
  5. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 5、 2の画像 1 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 5、 2の画像 2
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  6. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 6、 3の画像 1 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 6、 3の画像 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 6、 3の画像 3
    • Unscrew the 5.2mm screws holding the hard drive in place.
    • Gently pull the rubber hard drive mount to the side.
    • Pull the drive out.
  7. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Display Assembly: 手順 7、 1の画像 1
    • Remove the 8.5mm screws holding the bottom half of the laptop together.
  8. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 8、 2の画像 1 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 8、 2の画像 2
    • Take a metal separater and gently pry open the back end of the laptop halves.
  9. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 9、 2の画像 1 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 9、 2の画像 2
    • Remove the connector connecting the screen and the motherboard
  10. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 10、 2の画像 1 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 10、 2の画像 2
    • Unscrew the 6.8mm screws holding the hinges of the screen to the bottom half of the computer.
    • Detach the screen from the hinges of the laptop.
    • Be careful not to damage the connecting wires when detaching the screen.
  11. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 11、 2の画像 1 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 11、 2の画像 2
    • Use a metal separator to carefully separate the bottom half of the laptop.
  12. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: 手順 12、 1の画像 1
    • Gently unplug the cables connecting the screen to the motherboard.
    • The display assembly can now be freely separated.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sully Chen
メンバー登録日: 01/22/18
435 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S11-G5, Banghart Winter 2018 Cal Poly, Team S11-G5, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S11G5
4 メンバー
5のガイドは作成済み
コメント 1 件
Super helpful.
Upon re-pasting GPU I noticed that not only GPU chip was covered in thermal paste surrounding chips were literately covered with thermal paste to is that normal?
Timepusher - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 1,842
