メインコンテンツにスキップ
ASUS ROG G46VW Indicator Lights Replacement
必要な工具と部品
  1. ASUS ROG G46VW Indicator Lights Replacement, RAM: 手順 1、 2の画像 1 ASUS ROG G46VW Indicator Lights Replacement, RAM: 手順 1、 2の画像 2
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. ASUS ROG G46VW Indicator Lights Replacement: 手順 2、 1の画像 1
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. ASUS ROG G46VW Indicator Lights Replacement: 手順 3、 2の画像 1 ASUS ROG G46VW Indicator Lights Replacement: 手順 3、 2の画像 2
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. ASUS ROG G46VW Indicator Lights Replacement: 手順 4、 1の画像 1
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. ASUS ROG G46VW Indicator Lights Replacement: 手順 5、 1の画像 1
    • Repeat steps 3-4 to remove the second RAM stick.
  6. ASUS ROG G46VW Indicator Lights Replacement, Speaker Cover: 手順 6、 1の画像 1
    • Gently pry the back hinge cover piece away from the device.
  7. ASUS ROG G46VW Indicator Lights Replacement: 手順 7、 1の画像 1
    • Disconnect the speaker cable from the motherboard.
  8. ASUS ROG G46VW Indicator Lights Replacement, Keyboard: 手順 8、 1の画像 1
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Indicator Lights Replacement: 手順 9、 1の画像 1
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Indicator Lights Replacement: 手順 10、 1の画像 1
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Indicator Lights Replacement: 手順 11、 1の画像 1
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Indicator Lights Replacement: 手順 12、 2の画像 1 ASUS ROG G46VW Indicator Lights Replacement: 手順 12、 2の画像 2
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Indicator Lights Replacement, Indicator Lights: 手順 13、 1の画像 1
    • With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
  14. ASUS ROG G46VW Indicator Lights Replacement: 手順 14、 1の画像 1
    • Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Pull the plastic white housing piece away from the case.
  15. ASUS ROG G46VW Indicator Lights Replacement: 手順 15、 1の画像 1
    • Locate the flat LED cable that connects the lights to the motherboard.
    • Flip the black cover upwards before pulling on the cable.
    • Repeat for the other connector piece.
終わりに
作成者
3人の作成者と共同で作成されました。
Nicolas Catano
メンバー登録日: 09/24/18
104 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S6-G3, Thompson Fall 2018 University of North Texas, Team S6-G3, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S6G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 341
