メインコンテンツにスキップ
ASUS Q400A-BHI7N03 RAM Replacement
必要な工具と部品
  1. ASUS Q400A-BHI7N03 RAM Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 RAM Replacement: 手順 2、 1の画像 1
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 RAM Replacement: 手順 3、 2の画像 1 ASUS Q400A-BHI7N03 RAM Replacement: 手順 3、 2の画像 2
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
  4. ASUS Q400A-BHI7N03 RAM Replacement, RAM: 手順 4、 1の画像 1
    • Flip the laptop so that it is upside down and locate a screw near the middle of the laptop. Remove the 8 mm PH0 screw.
  5. ASUS Q400A-BHI7N03 RAM Replacement: 手順 5、 2の画像 1 ASUS Q400A-BHI7N03 RAM Replacement: 手順 5、 2の画像 2
    • Use a spudger or opening tool to remove the L shaped section of the back cover.
    • To avoid breaking the plastic, alternate the sides where you pry.
  6. ASUS Q400A-BHI7N03 RAM Replacement: 手順 6、 3の画像 1 ASUS Q400A-BHI7N03 RAM Replacement: 手順 6、 3の画像 2 ASUS Q400A-BHI7N03 RAM Replacement: 手順 6、 3の画像 3
    • The RAM is located in the top of the section you uncovered.
    • Identify the two metal tabs on both sides of the RAM.
    • Gently push both tabs outwards at the same time. The RAM will pop up.
    • Carefully pull the RAM out.
  7. ASUS Q400A-BHI7N03 RAM Replacement: 手順 7、 2の画像 1 ASUS Q400A-BHI7N03 RAM Replacement: 手順 7、 2の画像 2
    • To put RAM back in, lineup the RAM with the plastic holder.
    • Slide it into the slot at a 30 degree angle and push down until it clicks into place.
終わりに
作成者
8人の作成者と共同で作成されました。
Matthew Gold
メンバー登録日: 01/19/17
401 ポイント
4のガイドは作成済み
チーム
UC Davis, Team 1-4, Rodger Winter 2017 UC Davis, Team 1-4, Rodger Winter 2017人のメンバー
UCD-RODGER-W17S1G4
5 メンバー
4のガイドは作成済み
2 件のコメント
Hello there ! I got a question. What type of ram should I buy to replace my Asus ? I trying to upgrade to 16 gb
rockygc1985 - 返信
If I only have 1 stick of 4gb, and assuming I won't be getting more, does it matter which slot I place it? Top or bottom (closer to the motherboard) ? Thanks ahead of time!
John H - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 684
