はじめに
This guide will demonstrate how to remove the pair of speakers. This process is straightforward, and no special tools are necessary.
必要な工具と部品
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
The two in-house speakers are located near the sides of the device with the motherboard in between.
Remove the two 2.35 mm Phillips #1 screws from each speaker.
ある他の人がこのガイドを完成しました。
