メインコンテンツにスキップ
ASUS Portable AiO PT2001 Hard Drive Replacement
必要な工具と部品
  1. ASUS Portable AiO PT2001 Hard Drive Replacement, Back Panel: 手順 1、 3の画像 1 ASUS Portable AiO PT2001 Hard Drive Replacement, Back Panel: 手順 1、 3の画像 2 ASUS Portable AiO PT2001 Hard Drive Replacement, Back Panel: 手順 1、 3の画像 3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 2、 3の画像 1 ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 2、 3の画像 2 ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 2、 3の画像 3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 3、 3の画像 1 ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 3、 3の画像 2 ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 3、 3の画像 3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
  4. ASUS Portable AiO PT2001 Hard Drive Replacement, Hard Drive: 手順 4、 1の画像 1
    • Remove the four 5.0 mm Phillips #1 screws on the outer casing of the hard drive.
  5. ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 5、 2の画像 1 ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 5、 2の画像 2
    • Gently pull the hard drive away to disconnect it from the motherboard.
  6. ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 6、 1の画像 1
    • Remove the four 3.5 mm Phillips #1 screws on the edges of the outer casing, two on each side.
  7. ASUS Portable AiO PT2001 Hard Drive Replacement: 手順 7、 1の画像 1
    • Separate the hard drive from the casing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Runjia Chen
メンバー登録日: 04/18/18
295 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G5, Livingston Spring 2018 Cal Poly, Team S17-G5, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S17G5
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 11
過去 30 日: 31
今までの合計 3,451
