メインコンテンツにスキップ
ASUS Portable AiO PT2001 Battery Replacement
必要な工具と部品
  1. ASUS Portable AiO PT2001 Battery Replacement, Back Panel: 手順 1、 3の画像 1 ASUS Portable AiO PT2001 Battery Replacement, Back Panel: 手順 1、 3の画像 2 ASUS Portable AiO PT2001 Battery Replacement, Back Panel: 手順 1、 3の画像 3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. ASUS Portable AiO PT2001 Battery Replacement: 手順 2、 3の画像 1 ASUS Portable AiO PT2001 Battery Replacement: 手順 2、 3の画像 2 ASUS Portable AiO PT2001 Battery Replacement: 手順 2、 3の画像 3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. ASUS Portable AiO PT2001 Battery Replacement: 手順 3、 3の画像 1 ASUS Portable AiO PT2001 Battery Replacement: 手順 3、 3の画像 2 ASUS Portable AiO PT2001 Battery Replacement: 手順 3、 3の画像 3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
  4. ASUS Portable AiO PT2001 Battery Replacement, Battery: 手順 4、 1の画像 1
    • Remove the eight 3.5 mm Phillips screws that secure the battery.
  5. ASUS Portable AiO PT2001 Battery Replacement: 手順 5、 2の画像 1 ASUS Portable AiO PT2001 Battery Replacement: 手順 5、 2の画像 2
    • Disconnect the wires by pulling on the tab. Disconnecting these wires will clear the way for removing the battery.
  6. ASUS Portable AiO PT2001 Battery Replacement: 手順 6、 1の画像 1
    • Unplug the battery's connector from the motherboard.
  7. ASUS Portable AiO PT2001 Battery Replacement: 手順 7、 1の画像 1
    • Pull the battery out. Be careful not to break the cables on top.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Runjia Chen
メンバー登録日: 04/18/18
295 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G5, Livingston Spring 2018 Cal Poly, Team S17-G5, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S17G5
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 26
今までの合計 2,294
