この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is your device plugged in and still not charging? Have you tried using different chargers and still no luck? Follow this guide to replace the battery inside your device. All you will need are the plastic opening tools.
必要な工具と部品
Insert the plastic opening tool between the edge of the screen and the back cover.
Gently pry them apart. Use hands to pull them apart if necessary.
もう少しです!
終わりに
