メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Is your device plugged in and still not charging? Have you tried using different chargers and still no luck? Follow this guide to replace the battery inside your device. All you will need are the plastic opening tools.
パーツ
パーツは指定されていません。
  1. Insert the plastic opening tool between the edge of the screen and the back cover.
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires. Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. Disconnect the ribbon from the motherboard by gently pulling with your fingers. Using the opening tools, pry the battery off of the adhesive. Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
終わりに
Alexzander Pastore
メンバー登録日: 2018年10月26日
389 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G7, Peak Fall 2018 UMass Dartmouth, Team S2-G7, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S2G7
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 277
