メインコンテンツにスキップ
ASUS PadFone X Station Power and Volume Contacts Replacement
必要な工具と部品
  1. ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: 手順 1、 2の画像 1 ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: 手順 1、 2の画像 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Power and Volume Contacts Replacement, Locate CON1501: 手順 2、 1の画像 1
    • Locate CON1501
    • CON1501 will be visible underneath the contacts. You can readily see this if you look for the orange strip of film in the top right corner of the back of the Asus Padfone X Docking Station.
  3. ASUS PadFone X Station Power and Volume Contacts Replacement, Remove (1) phillips screw.: 手順 3、 1の画像 1
    • Remove (1) phillips screw
    • Using a +PH00 Phillips screwdriver , you will unscrew the Phillips screw in the top right corner of the back of the ASUS Padfone X docking station.
    • To unscrew the Phillips screw simply position the screwdriver inside of the screw, then rotate it counter-clockwise until the screw is fully removed from the docking station.
  4. ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: 手順 4、 2の画像 1 ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: 手順 4、 2の画像 2
    • Disconnect ribbon from CON1510
    • To disconnect the ribbon from CON1510, use a pair of tweezers and gently lift the connect up and back from the device.
  5. ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: 手順 5、 3の画像 1 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: 手順 5、 3の画像 2 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: 手順 5、 3の画像 3
    • Now that the contacts are no longer attached, you can use either tweezers or your fingers to grasp and lift contacts vertically off of the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jessica
メンバー登録日: 10/07/14
150 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S7G4
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 531
