はじめに
You will be looking for water damage on the USB connector and replacing the 1413 USB/ANT docking connector.
必要な工具と部品
Using the plastic opening tools, insert it into the edge and pry open.
Use hands to help pull the back off from the front if needed.
Locate the CON101
The white sticker indicates water exposure. White=none, Red=Exposure
These are the antenna wires.
Trace these wires to locate the two antennas.
ある他の人がこのガイドを完成しました。
