メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: 手順 1、 2の画像 1 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: 手順 1、 2の画像 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: 手順 2、 3の画像 1 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: 手順 2、 3の画像 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: 手順 2、 3の画像 3
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: 手順 3、 2の画像 1 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: 手順 3、 2の画像 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: 手順 4、 1の画像 1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: 手順 5、 1の画像 1
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: 手順 6、 1の画像 1
    • Once the camera has been pulled out, replace the old camera with a new camera.
終わりに
nestor
メンバー登録日: 2014年10月07日
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S8G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 477
