必要な工具と部品
Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
Work your way around the phone until the entire back cover is loose.
Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose and remove the mid-frame.
Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
Once the camera has been pulled out, replace the old camera with a new camera.
