メインコンテンツにスキップ
ASUS PadFone X Motherboard Replacement
必要な工具と部品
  1. ASUS PadFone X Motherboard Replacement, Motherboard: 手順 1、 2の画像 1 ASUS PadFone X Motherboard Replacement, Motherboard: 手順 1、 2の画像 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Motherboard Replacement: 手順 2、 2の画像 1 ASUS PadFone X Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the thirteen 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Motherboard Replacement: 手順 3、 2の画像 1 ASUS PadFone X Motherboard Replacement: 手順 3、 2の画像 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Motherboard Replacement: 手順 4、 1の画像 1
    • Using the plastic blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force will damage the connector.
  5. ASUS PadFone X Motherboard Replacement: 手順 5、 2の画像 1 ASUS PadFone X Motherboard Replacement: 手順 5、 2の画像 2
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
  6. ASUS PadFone X Motherboard Replacement: 手順 6、 1の画像 1
    • Using a spudger, pry the vibration motor connector from the motherboard.
  7. ASUS PadFone X Motherboard Replacement: 手順 7、 1の画像 1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force will damage the conector
  8. ASUS PadFone X Motherboard Replacement: 手順 8、 1の画像 1
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  9. ASUS PadFone X Motherboard Replacement: 手順 9、 2の画像 1 ASUS PadFone X Motherboard Replacement: 手順 9、 2の画像 2
    • Insert the tip of the flat head screwdriver between the panel and the metal clip then gently push down until the clip is slightly bent away from the panel.
    • Do this for all the clips holding the panel down.
    • After all clips are bent away, remove the panel.
  10. ASUS PadFone X Motherboard Replacement: 手順 10、 2の画像 1 ASUS PadFone X Motherboard Replacement: 手順 10、 2の画像 2
    • Disconnect the first connector by prying it upward using the blue plastic opening tool.
    • Disconnect the second connector by first lifting the lock then pulling the connector outward.
  11. ASUS PadFone X Motherboard Replacement: 手順 11、 3の画像 1 ASUS PadFone X Motherboard Replacement: 手順 11、 3の画像 2 ASUS PadFone X Motherboard Replacement: 手順 11、 3の画像 3
    • Insert the tip of the blue plastic opening tool under the motherboard and gently pry upward.
    • Work your way around until the motherboard is free.
  12. ASUS PadFone X Motherboard Replacement: 手順 12、 1の画像 1
    • Flip the motherboard over and locate the front facing camera.
    • Using the tweezers gently remove the black locking mechanism.
    • The black locking mechanism is very fragile and extreme care should be exercised during removal.
  13. ASUS PadFone X Motherboard Replacement: 手順 13、 2の画像 1 ASUS PadFone X Motherboard Replacement: 手順 13、 2の画像 2
    • Use the tweezers to gently pull on the connector to remove the camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Ryan
メンバー登録日: 05/14/12
223 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S8G4
4 メンバー
5のガイドは作成済み
4 件のコメント
There is a step missing between step 10 and 11, you didn't explain how to remove the flexible connector that go's to the power/volume buttons next to the camera location on the side of the phone.
David Baxter - 返信
which I only had to gently pry up on the connector from the center of the phone out and it came right off.
David Baxter - 返信
Hey iFixits,
I have a Padfone S (international version, supposedly the same as the Padfone X sold in the states), which suffered water damage. I presume the logic board needs replacing and since there are more Padfone X's out there, thinking of buying a 'for parts' phone with say, a broken screen, and just swapping logic boards to make one working phone. Does anyone know if these logic boards for the S and X are compatible?? Thanks in advance.
Jack - 返信
I have Asus padfone 2 the phones motherboard is damaged how to use the pad
tushar.modak - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 12
今までの合計 1,993
