はじめに
Motherboard is one of the most important parts on a device, This guide will help you take apart your Asus MeMo Pad 7 to get access to your motherboard. This will allow you to replace your motherboard and the device will work properly.
必要な工具と部品
Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
After removing the battery from the device, locate the volume connectors on the side of the device.
Using tweezers, carefully remove the volume connectors and place it to the side.
3 の人々がこのガイドを完成させました。
3 件のコメント
Many thanks to this guide. With the instruction I could repair my dead screen. The yellow/orange screen cable was just a little bit out after a 40 cm drop. Just pushing the battery a little bit in the direction of the motherboard was enough to reconnect the screen … I suspect that the weight of the battery pulled the video cable out of the the connector as the video cable is attached to the battery pack with adhesive tape.
