メインコンテンツにスキップ
ASUS MeMO Pad 7 (ME572C) Front Camera Replacement
必要な工具と部品
  1. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Rear Panel: 手順 1、 2の画像 1 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Rear Panel: 手順 1、 2の画像 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 2、 3の画像 1 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 2、 3の画像 2 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 2、 3の画像 3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 3、 1の画像 1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
  4. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Battery: 手順 4、 3の画像 1 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Battery: 手順 4、 3の画像 2 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Battery: 手順 4、 3の画像 3
    • Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
    • You can also use your hand to remove ZIF connectors.
    • ZIF connectors are delicate so be careful when you are removing them.
  5. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 5、 1の画像 1
    • Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
  6. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 6、 3の画像 1 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 6、 3の画像 2 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 6、 3の画像 3
    • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
    • The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out.
  7. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Motherboard: 手順 7、 2の画像 1 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Motherboard: 手順 7、 2の画像 2
    • After removing the battery from the device, locate the volume connectors on the side of the device.
    • Using tweezers, carefully remove the volume connectors and place it to the side.
  8. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 8、 2の画像 1 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 8、 2の画像 2
    • Locate the GPS antenna. Pry off the GPS antenna cable with a spudger.
  9. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 9、 2の画像 1 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 9、 2の画像 2
    • Locate seven 2mm Phillips #0 screws attaching the motherboard to the pad. Remove the screws with a Phillips #000 screwdriver.
    • Place your screws somewhere you will remember they are at.
  10. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement: 手順 10、 1の画像 1
    • Once all the screws are taken out, you can remove the motherboard. Carefully, take the motherboard out with a plastic opening tool.
  11. ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Front Camera: 手順 11、 3の画像 1 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Front Camera: 手順 11、 3の画像 2 ASUS MeMO Pad 7 (ME572C) Front Camera Replacement, Front Camera: 手順 11、 3の画像 3
    • Flip the motherboard and find the place where the front camera connector is.
    • Using tweezers, carefully remove the front camera connectors and place it to the side.
終わりに
作成者
2人の作成者と共同で作成されました。
Efe Guldogan
メンバー登録日: 08/26/15
860 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 14-23, Meier Fall 2015 USF Tampa, Team 14-23, Meier Fall 2015人のメンバー
USFT-MEIER-F15S14G23
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 993
