はじめに
Sometimes screens stop working. This guide will show you how to replace your screen and get back to browsing.
必要な工具と部品
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
ある他の人がこのガイドを完成しました。
3 件のコメント
Thank you for your time!
Now, I don´t know how to connect the cables to the motherboard because they are too short.
