メインコンテンツにスキップ
ASUS K200MA-DS01T Fan Replacement
必要な工具と部品
  1. ASUS K200MA-DS01T Fan Replacement, Back Panel: 手順 1、 2の画像 1 ASUS K200MA-DS01T Fan Replacement, Back Panel: 手順 1、 2の画像 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Fan Replacement: 手順 2、 2の画像 1 ASUS K200MA-DS01T Fan Replacement: 手順 2、 2の画像 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Fan Replacement: 手順 3、 1の画像 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Fan Replacement: 手順 4、 3の画像 1 ASUS K200MA-DS01T Fan Replacement: 手順 4、 3の画像 2 ASUS K200MA-DS01T Fan Replacement: 手順 4、 3の画像 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Fan Replacement, Keyboard: 手順 5、 2の画像 1 ASUS K200MA-DS01T Fan Replacement, Keyboard: 手順 5、 2の画像 2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Fan Replacement: 手順 6、 2の画像 1 ASUS K200MA-DS01T Fan Replacement: 手順 6、 2の画像 2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Fan Replacement, Battery: 手順 7、 2の画像 1 ASUS K200MA-DS01T Fan Replacement, Battery: 手順 7、 2の画像 2
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. ASUS K200MA-DS01T Fan Replacement: 手順 8、 3の画像 1 ASUS K200MA-DS01T Fan Replacement: 手順 8、 3の画像 2 ASUS K200MA-DS01T Fan Replacement: 手順 8、 3の画像 3
    • Gripping the wider left section, lift the battery up and away from computer.
  9. ASUS K200MA-DS01T Fan Replacement, Fan: 手順 9、 2の画像 1 ASUS K200MA-DS01T Fan Replacement, Fan: 手順 9、 2の画像 2
    • Locate the fan, two screws and two color coded wires in the bottom left corner of the computer.
  10. ASUS K200MA-DS01T Fan Replacement: 手順 10、 1の画像 1
    • Remove the following screws from the fan:
    • Two 4mm screws using a Phillips #0 screwdriver.
  11. ASUS K200MA-DS01T Fan Replacement: 手順 11、 2の画像 1 ASUS K200MA-DS01T Fan Replacement: 手順 11、 2の画像 2
    • Firmly pull colored wires away from wire slot.
  12. ASUS K200MA-DS01T Fan Replacement: 手順 12、 2の画像 1 ASUS K200MA-DS01T Fan Replacement: 手順 12、 2の画像 2
    この手順で使用する道具:
    購入する
    • After removing both the screws and color coded wires, lift fan out of place.
    • Tools such as spudgers or tweezers may be used for fan removal.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Terrinda
メンバー登録日: 09/17/18
526 ポイント
4のガイドは作成済み
チーム
CSU Fullerton, Team S2-G5, Bruce Fall 2018 CSU Fullerton, Team S2-G5, Bruce Fall 2018人のメンバー
CSUF-BRUCE-F18S2G5
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 127
