メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ASUS F550 RAM Replacement
必要な工具と部品
  1. ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: 手順 1、 2の画像 1 ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: 手順 1、 2の画像 2
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
    FixBotに聞いてみる
  2. ASUS F550 RAM Replacement, Remove Ram: 手順 2、 2の画像 1 ASUS F550 RAM Replacement, Remove Ram: 手順 2、 2の画像 2
    • Release securing arms and remove RAM.
    FixBotに聞いてみる
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ryan
メンバー登録日: 08/19/15
1,519 ポイント
14のガイドは作成済み
3件のガイドコメント
Pretty sure only 2 of the 4 screws need to be removed.
tobiaskuhn - 返信 共有
Can confirm only two screws required removal to enable access on my model F550C
Have successfully replaced HD once, but had slight issue getting it recognised
which is more of a BIOS issue, helps if you have a seperate bootable USB drive
but once recognised and OS installed, have several times swapped between the two
HDs (one Win8, one Linux - eventually plan to only use linux on this system).
Regards
Mike.
mihaly_k - 返信 共有
Yes only two need to be removed, however I initially wrote a tear down to gain access to the network card etc and the way ifix it is structured for guide creation these steps are in fact used in that longer guide. I've amended the instructions now so hopefully they are more clear now.
Ryan - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 69
今までの合計 5,122
