メインコンテンツにスキップ
ASUS Eee Pad Transformer Screen Replacement
必要な工具と部品
  1. ASUS Eee Pad Transformer Screen Replacement, Back Panel: 手順 1、 2の画像 1 ASUS Eee Pad Transformer Screen Replacement, Back Panel: 手順 1、 2の画像 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Screen Replacement: 手順 2、 3の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 2、 3の画像 2 ASUS Eee Pad Transformer Screen Replacement: 手順 2、 3の画像 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Screen Replacement: 手順 3、 1の画像 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Screen Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Screen Replacement: 手順 5、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Screen Replacement: 手順 6、 2の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 6、 2の画像 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Screen Replacement, Remove screws: 手順 7、 1の画像 1
    • Use Phillips #00 Screwdriver to remove four 3 millimeter screws found on the metal panel.
  8. ASUS Eee Pad Transformer Screen Replacement, Remove metal panel: 手順 8、 1の画像 1
    • Metal panel is glued to the battery. Remove with care.
    • Use Plastic Opening Tool to pry off the metal panel from the battery starting on the right side corners and working around the rest of the panel.
  9. ASUS Eee Pad Transformer Screen Replacement, Detach wires: 手順 9、 1の画像 1
    • Do NOT pry the battery connector upward as shown in this photo. Instead, pull the connector straight out (in the direction of the wires).
  10. ASUS Eee Pad Transformer Screen Replacement, Remove battery: 手順 10、 3の画像 1 ASUS Eee Pad Transformer Screen Replacement, Remove battery: 手順 10、 3の画像 2 ASUS Eee Pad Transformer Screen Replacement, Remove battery: 手順 10、 3の画像 3
    • Battery is glued to device. Remove with care.
    • Peel off tape from around the edges of the battery.
    • Insert Plastic Opening Tool into slot on side of battery found near the wire bundle.
    • Lift up the battery off of the device.
  11. ASUS Eee Pad Transformer Screen Replacement, Motherboard: 手順 11、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the six 3 millimeter screws securing the motherboard to the screen.
  12. ASUS Eee Pad Transformer Screen Replacement: 手順 12、 2の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 12、 2の画像 2
    • Detach the Wifi and GPS antennas (three coaxial cables connected to the motherboard) using hands,metal spudger, or tweezers by lifting away from the device.
  13. ASUS Eee Pad Transformer Screen Replacement: 手順 13、 2の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 13、 2の画像 2
    • Use fingers, plastic opening tool, or metal spudger to lift the clips to the ZIF connector. Remove the ribbon cables attached underneath.
  14. ASUS Eee Pad Transformer Screen Replacement: 手順 14、 1の画像 1
    • Remove any tape that is holding down any free wires.
    • Carefully lift the motherboard and slide it out from underneath its constraints.
  15. ASUS Eee Pad Transformer Screen Replacement: 手順 15、 2の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 15、 2の画像 2
    • Unclip the ribbon cable from the ZIF connector using a plastic opening tool or metal spudger.
    • Remove any taped on accessories
  16. ASUS Eee Pad Transformer Screen Replacement, Screen: 手順 16、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the four 3 millimeter screws securing the two black ports at the bottom.
  17. ASUS Eee Pad Transformer Screen Replacement: 手順 17、 3の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 17、 3の画像 2 ASUS Eee Pad Transformer Screen Replacement: 手順 17、 3の画像 3
    • Use a Phillips #00 Screwdriver to remove the two 3 millimeter screws securing the charging port to the screen.
    • Carefully remove the charging port by lifting the metal end and carefully sliding the plastic attached underneath the grey screen constraint.
  18. ASUS Eee Pad Transformer Screen Replacement: 手順 18、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing volume button board.
  19. ASUS Eee Pad Transformer Screen Replacement: 手順 19、 2の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 19、 2の画像 2
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the headphone jack board.
    • Unclip the No-fuss ribbon cable connector using your fingernail or metal spudger.
  20. ASUS Eee Pad Transformer Screen Replacement: 手順 20、 2の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 20、 2の画像 2
    • Use fingers, plastic opening tool, or metal spudger to lift the clip securing the display cable and remove by sliding it out.
  21. ASUS Eee Pad Transformer Screen Replacement: 手順 21、 2の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 21、 2の画像 2
    • Use fingers, plastic opening tool, or metal spudger to lift the glued-in left and right speaker.
  22. ASUS Eee Pad Transformer Screen Replacement: 手順 22、 3の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 22、 3の画像 2 ASUS Eee Pad Transformer Screen Replacement: 手順 22、 3の画像 3
    • Detach the Wifi and GPS antenna from the screen. This piece is glued down so use a metal spudger to get under the piece and lift up.
    • Use a metal spudger to lift up the small electric board next to the camera. This piece is glued down as well as secured by plastic pillars.
    • Using a metal spudger, lift the camera out of its spot. The camera is glued down.
  23. ASUS Eee Pad Transformer Screen Replacement: 手順 23、 2の画像 1 ASUS Eee Pad Transformer Screen Replacement: 手順 23、 2の画像 2
    • Detach the two ZIF connectors using your fingers, plastic opening tool, or metal spudger.
    • Using a metal spudger lift up the glued down motherboard.
  24. ASUS Eee Pad Transformer Screen Replacement: 手順 24、 1の画像 1
    • This is what the final screen should look like after everything is removed.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Brian Haskell
メンバー登録日: 11/01/18
316 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S2-G5, Harley Fall 2018 IUPUI, Team S2-G5, Harley Fall 2018人のメンバー
IUPUI-HARLEY-F18S2G5
3 メンバー
2のガイドは作成済み
コメント 1 件
First Class for your Instruction.
With Best Regards
Jürgen Pogoda
Jürgen Pogoda - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 1,165
