メインコンテンツにスキップ
ASUS Eee Pad Transformer Motherboard Replacement
必要な工具と部品
  1. ASUS Eee Pad Transformer Motherboard  Replacement, Back Panel: 手順 1、 2の画像 1 ASUS Eee Pad Transformer Motherboard  Replacement, Back Panel: 手順 1、 2の画像 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Motherboard  Replacement: 手順 2、 3の画像 1 ASUS Eee Pad Transformer Motherboard  Replacement: 手順 2、 3の画像 2 ASUS Eee Pad Transformer Motherboard  Replacement: 手順 2、 3の画像 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Motherboard  Replacement: 手順 3、 1の画像 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Motherboard  Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Motherboard  Replacement: 手順 5、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Motherboard  Replacement: 手順 6、 2の画像 1 ASUS Eee Pad Transformer Motherboard  Replacement: 手順 6、 2の画像 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Motherboard  Replacement, Remove screws: 手順 7、 1の画像 1
    • Use Phillips #00 Screwdriver to remove four 3 millimeter screws found on the metal panel.
  8. ASUS Eee Pad Transformer Motherboard  Replacement, Remove metal panel: 手順 8、 1の画像 1
    • Metal panel is glued to the battery. Remove with care.
    • Use Plastic Opening Tool to pry off the metal panel from the battery starting on the right side corners and working around the rest of the panel.
  9. ASUS Eee Pad Transformer Motherboard  Replacement, Detach wires: 手順 9、 1の画像 1
    • Do NOT pry the battery connector upward as shown in this photo. Instead, pull the connector straight out (in the direction of the wires).
  10. ASUS Eee Pad Transformer Motherboard  Replacement, Remove battery: 手順 10、 3の画像 1 ASUS Eee Pad Transformer Motherboard  Replacement, Remove battery: 手順 10、 3の画像 2 ASUS Eee Pad Transformer Motherboard  Replacement, Remove battery: 手順 10、 3の画像 3
    • Battery is glued to device. Remove with care.
    • Peel off tape from around the edges of the battery.
    • Insert Plastic Opening Tool into slot on side of battery found near the wire bundle.
    • Lift up the battery off of the device.
  11. ASUS Eee Pad Transformer Motherboard  Replacement, Motherboard: 手順 11、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the six 3 millimeter screws securing the motherboard to the screen.
  12. ASUS Eee Pad Transformer Motherboard  Replacement: 手順 12、 2の画像 1 ASUS Eee Pad Transformer Motherboard  Replacement: 手順 12、 2の画像 2
    この手順で使用する道具:
    購入する
    • Detach the Wifi and GPS antennas (three coaxial cables connected to the motherboard) using hands,metal spudger, or tweezers by lifting away from the device.
  13. ASUS Eee Pad Transformer Motherboard  Replacement: 手順 13、 2の画像 1 ASUS Eee Pad Transformer Motherboard  Replacement: 手順 13、 2の画像 2
    • Use fingers, plastic opening tool, or metal spudger to lift the clips to the ZIF connector. Remove the ribbon cables attached underneath.
  14. ASUS Eee Pad Transformer Motherboard  Replacement: 手順 14、 1の画像 1
    • Remove any tape that is holding down any free wires.
    • Carefully lift the motherboard and slide it out from underneath its constraints.
  15. ASUS Eee Pad Transformer Motherboard  Replacement: 手順 15、 2の画像 1 ASUS Eee Pad Transformer Motherboard  Replacement: 手順 15、 2の画像 2
    • Unclip the ribbon cable from the ZIF connector using a plastic opening tool or metal spudger.
    • Remove any taped on accessories
終わりに
作成者
2人の作成者と共同で作成されました。
Brian Haskell
メンバー登録日: 11/01/18
316 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S2-G5, Harley Fall 2018 IUPUI, Team S2-G5, Harley Fall 2018人のメンバー
IUPUI-HARLEY-F18S2G5
3 メンバー
2のガイドは作成済み
コメント 1 件
i was wondering if i was to purchase a motherboard from ebay that is out of the same model as mine, would their be any issues with the operation after or would oit work like normal..for example, i noticed when i was looking for one online, often times in the description was some kind of id or serial number. i noticed their are stickers on the board itself that seems to correlate with the ones listed in the ads. mine always matched theirs except for the final 3 numbers/letters. if i was to buy one, would their be any issues as far as functionality goes?
Daniel Ogden - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 791
