メインコンテンツにスキップ
ASUS Eee Pad Transformer Buttons Replacement
必要な工具と部品
  1. ASUS Eee Pad Transformer Buttons Replacement, Back Panel: 手順 1、 2の画像 1 ASUS Eee Pad Transformer Buttons Replacement, Back Panel: 手順 1、 2の画像 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Buttons Replacement: 手順 2、 3の画像 1 ASUS Eee Pad Transformer Buttons Replacement: 手順 2、 3の画像 2 ASUS Eee Pad Transformer Buttons Replacement: 手順 2、 3の画像 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Buttons Replacement: 手順 3、 1の画像 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Buttons Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Buttons Replacement: 手順 5、 1の画像 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Buttons Replacement: 手順 6、 2の画像 1 ASUS Eee Pad Transformer Buttons Replacement: 手順 6、 2の画像 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Buttons Replacement, Remove button screws: 手順 7、 2の画像 1 ASUS Eee Pad Transformer Buttons Replacement, Remove button screws: 手順 7、 2の画像 2
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the buttons to the back panel.
  8. ASUS Eee Pad Transformer Buttons Replacement, Locate and lift button clip: 手順 8、 3の画像 1 ASUS Eee Pad Transformer Buttons Replacement, Locate and lift button clip: 手順 8、 3の画像 2 ASUS Eee Pad Transformer Buttons Replacement, Locate and lift button clip: 手順 8、 3の画像 3
    • Use Plastic Opening Tool to pry off the clip located towards the bottom of the button component near the metallic strip with a blue end, capped by the black button clip.
    • Remove button component by pulling straight outward from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Joe Payne
メンバー登録日: 09/29/14
534 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-9, Forte Fall 2014 Cal Poly, Team 13-9, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S13G9
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 20
今までの合計 6,401
