はじめに
The back-facing camera is somewhat exposed on the device and therefore is susceptible to damage. Cameras are somewhat of a luxury on a device and may not be a crucial for extending the device's life, but a simple replacement is well worth the time.
パーツ
パーツは必要ありません。
Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
Use Tweezers to pull out gold flap connected to bottom of camera.
Pull the gold flap to take out the camera.
ある他の人がこのガイドを完成しました。
