メインコンテンツにスキップ
ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement
必要な工具と部品
  1. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Battery: 手順 1、 2の画像 1 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Battery: 手順 1、 2の画像 2
    • Flip the laptop over, you should see two battery tabs.
    • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
  2. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 2、 2の画像 1 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 2、 2の画像 2
    • While holding the left tab towards the left. Gently slide the battery out of the laptop.
  3. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Keyboard: 手順 3、 3の画像 1 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Keyboard: 手順 3、 3の画像 2 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Keyboard: 手順 3、 3の画像 3
    • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
    • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
    • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
  4. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 4、 3の画像 1 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 4、 3の画像 2 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 4、 3の画像 3
    • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
    • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
    • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
  5. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Touchpad and Mouse Buttons: 手順 5、 1の画像 1
    • Remove all six 3.4mm Phillips #1 screws marked with red circles.
  6. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 6、 2の画像 1 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 6、 2の画像 2
    • On either end of the ribbon cable clamp, carefully push the tab towards the right, using a nylon spudger.
    • The ribbon cable can now be pulled out using the blue tab attached to the cable.
  7. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 7、 2の画像 1 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 7、 2の画像 2
    • Move the screen as far back as possible, and pry apart the plastic clips on the inside and outside of the hinges. They should be pushed upwards.
    • Use a spudger between the metal and white plastic, and carefully pry them apart to dislodge the clips.
  8. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 8、 1の画像 1
    • Pry the top cover off of the laptop. This should come off easily if you have removed all the tabs.
    • Be careful around the audio jack area. You may need to slide the cover towards the left and around the headphone and microphone jacks.
  9. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 9、 3の画像 1 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 9、 3の画像 2 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: 手順 9、 3の画像 3
    • Flip over the top cover and unscrew the two 1.2mm Phillips #0 screws.
    • Remove the plate and the trackpad. They may come off separately.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Vinny Micale
メンバー登録日: 03/21/17
225 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 UMass Dartmouth, Team S2-G8, Isaacson Spring 2017人のメンバー
UMASSD-ISAACSON-S17S2G8
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 27
今までの合計 1,019
