メインコンテンツにスキップ
ASUS D550MA-DS01 Keyboard Module Replacement
必要な工具と部品
  1. ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: 手順 1、 2の画像 1 ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: 手順 1、 2の画像 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
  2. ASUS D550MA-DS01 Keyboard Module Replacement: 手順 2、 1の画像 1
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
  3. ASUS D550MA-DS01 Keyboard Module Replacement: 手順 3、 2の画像 1 ASUS D550MA-DS01 Keyboard Module Replacement: 手順 3、 2の画像 2
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
    I need assistance. When I opened the cover, exposing the keyboard and main board I pulled the 3 blue and white data cables from the main board. How can I repair this? Someone please help!!!!!!
    Angela Rene'e Dortch - 返信
  4. ASUS D550MA-DS01 Keyboard Module Replacement: 手順 4、 1の画像 1
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  5. ASUS D550MA-DS01 Keyboard Module Replacement: 手順 5、 1の画像 1
    • Remove the fully disconnected keyboard module from the laptop.
    No need to remove the keyboard. The ribbons are plenty long to give slack and allow access.
    hellcat - 返信
    Good overall, thank you!
    hellcat - 返信
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
redacted
メンバー登録日: 09/15/15
543 ポイント
3のガイドは作成済み
3 件のコメント
Does anybody knows how to remove the keyboard from the keyboard module??I want to replace the keyboard not the whole piece
mfq1979 - 返信
where can I get a keyboard replacement
Kwame Mitchell - 返信
http://www.newegg.com
Replacement Keyboard N2840 s/n EBNOCX62041047D sold by, Alpha Vr Electronics, 860-755-2309 ext. 22831 $20.99
Eugene Bohrmann -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 1,870
