はじめに
This guide will take you through a step-by-step process for the removal of your Chromebook’s screen.
必要な工具と部品
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Disconnect the screen cable connector located on the top right of the motherboard.
Using a spudger, gently pry up the sides of the connector.
Pull the connector off with your fingers.
もう少しです!
終わりに
