メインコンテンツにスキップ
ASUS Chromebook C200MA DS01 Touchpad Replacement
必要な工具と部品
  1. ASUS Chromebook C200MA DS01 Touchpad Replacement, Back Panel: 手順 1、 1の画像 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 3、 1の画像 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: 手順 4、 3の画像 1 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: 手順 4、 3の画像 2 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: 手順 4、 3の画像 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: 手順 5、 2の画像 1 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: 手順 5、 2の画像 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 6、 1の画像 1
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Touchpad Replacement, Touchpad: 手順 7、 1の画像 1
    • Locate the touchpad.
    • Locate the touch pad cable connector.
  8. ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 8、 3の画像 1 ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 8、 3の画像 2 ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 8、 3の画像 3
    • Disconnect the touch pad ZIF(zero insertion force) connector.
    • Flip the flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to disconnect.
  9. ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 9、 1の画像 1
    • Gently remove the adhesive on the touch pad ribbon cable.
  10. ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 10、 3の画像 1 ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 10、 3の画像 2 ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 10、 3の画像 3
    • Gently remove the metallic tape from the touch pad only.
    • Try not to tear the tape, it can be re-used during reassembly.
  11. ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 11、 1の画像 1
    • Remove the three 1.8 mm Phillips #00 screws.
  12. ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 12、 2の画像 1 ASUS Chromebook C200MA DS01 Touchpad Replacement: 手順 12、 2の画像 2
    • Lift the far edge of the touch pad to remove it.
終わりに
作成者
2人の作成者と共同で作成されました。
Christopher Lim
メンバー登録日: 04/26/17
779 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S23G4
4 メンバー
19のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 582
