メインコンテンツにスキップ
ASUS Chromebook C200MA DS01 Speaker Replacement
必要な工具と部品
  1. ASUS Chromebook C200MA DS01 Speaker Replacement, Back Panel: 手順 1、 1の画像 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 3、 1の画像 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: 手順 4、 3の画像 1 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: 手順 4、 3の画像 2 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: 手順 4、 3の画像 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: 手順 5、 2の画像 1 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: 手順 5、 2の画像 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 6、 1の画像 1
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: 手順 7、 2の画像 1 ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: 手順 7、 2の画像 2
    • Disconnect the speaker's black bundled cable connector on the motherboard.
    • The cables are red, white and black.
    • Pinch the black bundled cable connector between your thumb and pointer finger and pull.
  8. ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 8、 2の画像 1 ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 8、 2の画像 2
    • Using your hands or the small plastic opening tool, pry the right speaker from the Chromebook.
    • There are small adhesives under the speakers that will provide moderate resistance.
  9. ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 9、 2の画像 1 ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 9、 2の画像 2
    • Disconnect the USB port ZIF(zero insertion force) connector that partially covers the left speaker.
    • Flip the ZIF retaining flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to remove it from the connector.
  10. ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 10、 2の画像 1 ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 10、 2の画像 2
    • Unravel the connecting cord between the two speakers.
  11. ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 11、 3の画像 1 ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 11、 3の画像 2 ASUS Chromebook C200MA DS01 Speaker Replacement: 手順 11、 3の画像 3
    • Using the small plastic opening tool, pry the left speaker from the Chromebook.
    • Remove the speakers.
    • There are small adhesives that will provide moderate resistance.
終わりに
作成者
4人の作成者と共同で作成されました。
Christopher Lim
メンバー登録日: 04/26/17
779 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S23G4
4 メンバー
19のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 247
